  • 1 Vote(s) - 5 Average
1936 Philco 116PX Electronic Restoration
(07-15-2017, 10:44 AM)klondike98 Wrote:  I believe it is probably the unlabeled 3uF cap circled here:
(schematic from Ron's annotated schematics in the Tech Section, with the circles added)
[Image: https://www.dropbox.com/s/0bnycedv0xr41i....jpg?raw=1]
THERE it is! Thank you! Sometimes another set of eyes helps. Thanks!
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
RE: 1936 Philco 116PX Electronic Restoration - by PhilcoPhan1936 - 07-15-2017, 12:42 PM
The speaker table error?
Philco 70 antenna lead
