  • 1 Vote(s) - 5 Average
1936 Philco 116PX Electronic Restoration
On my 116B I used a 22mf for the input cap and it boosted the B+ up about 50v. Since I had already had restuffed the can rather than taking it back apart (it's kinda tight and was using my Weller w/the short tip) I elected to put another 22 in series w/it behind the shield for the power resistor making 11mf vs 8mf. Brought the B+ down to a bit more reasonable level.
RE: 1936 Philco 116PX Electronic Restoration - by Radioroslyn - 07-15-2017, 01:32 PM
The speaker table error?
Philco 70 antenna lead
