Philco 48-482 low vol on AM
Yes...The IF cans were tweaked using a signal gen...
Using Sams 4720-24 the voltages on pins 3 and 6 of the 7F8 are off.Pin3= 115 should be 138
Pin 6= 111 should be 130
ON pins 5& 6 of the 7B6 are both -.45
pin 5 should be -.50 and pin 6 should be -.23
The rest of the tube pin voltages are ok..
Philco 48-482 low vol on AM - by Micro9 - 07-15-2017, 02:33 PM
RE: Philco 48-482 low vol on AM - by morzh - 07-15-2017, 02:47 PM
RE: Philco 48-482 low vol on AM - by klondike98 - 07-15-2017, 02:52 PM
RE: Philco 48-482 low vol on AM - by Micro9 - 07-15-2017, 03:46 PM
RE: Philco 48-482 low vol on AM - by Micro9 - 07-15-2017, 03:49 PM
RE: Philco 48-482 low vol on AM - by Radioroslyn - 07-16-2017, 02:48 AM
RE: Philco 48-482 low vol on AM - by Micro9 - 07-17-2017, 03:44 PM
RE: Philco 48-482 low vol on AM - by klondike98 - 07-17-2017, 06:27 PM
The speaker table error?
Philco 70 antenna lead
