RP-3 no range
Thanks Doug, Checked voltage at pickup.(OK) In doing so decided to make sure the connections were good. Tightened all related points. Put it all together, retried. Now I can pick it up in the next room. Funny how a bad connection can ruin a whole day. Thanks again, Richard
RP-3 no range - by rjm - 01-18-2006, 09:50 PM
RP-3 - by Doug Houston - 01-19-2006, 05:48 PM
[No subject] - by rjm - 01-19-2006, 06:38 PM
[No subject] - by Doug Houston - 01-20-2006, 02:45 PM
[No subject] - by rjm - 01-20-2006, 09:53 PM
42 RP-2 - by panther - 01-26-2006, 11:13 PM
There are currently 8476 online users. [Complete List]
» 1 Member(s) | 8475 Guest(s)
