  • 1 Vote(s) - 5 Average
1936 Philco 116PX Electronic Restoration
Not a bad idea either.
In this case I would specifically use low ESR capacitor after the choke, as the ripple voltage is pretty much the ripple current times the ESR.
RE: 1936 Philco 116PX Electronic Restoration - by morzh - 07-18-2017, 10:01 AM
The speaker table error?
Philco 70 antenna lead
