The (other) "P" word
So what do you think about Scotch Bright pads vs Steel wool? Doesn't leave small wires in the cracks and crevices.
Thoughts?
The (other) "P" word - by TimC - 02-09-2010, 11:14 AM
Re: The (other) "P" word - by denver - 02-09-2010, 11:52 AM
Re: The (other) "P" word - by TimC - 02-09-2010, 01:56 PM
Re: The (other) "P" word - by 7estatdef - 02-09-2010, 06:49 PM
Re: The (other) "P" word - by codefox1 - 02-09-2010, 07:01 PM
Re: The (other) "P" word - by exray - 02-10-2010, 07:15 AM
Re: The (other) "P" word - by denver - 02-10-2010, 09:42 AM
Re: The (other) "P" word - by exray - 02-11-2010, 11:26 PM
Re: The (other) "P" word - by Ron Ramirez - 02-15-2010, 11:30 AM
Re: The (other) "P" word - by exray - 02-15-2010, 10:07 PM
Re: The (other) "P" word - by denver - 02-16-2010, 06:59 PM
Re: The (other) "P" word - by TimC - 02-16-2010, 09:44 PM
Re: The (other) "P" word - by denver - 02-16-2010, 11:17 PM
Philco 91 Tuning Condenser
There are currently 10212 online users. [Complete List]
» 3 Member(s) | 10209 Guest(s)
