38-116 Code 121 Powering Up Help
It may be that the transformer was replaced and is good. If both halves are close in value. Another question, if it is a replacement, is it a good replacement.
DC resistance is not the goal. Power limit and turns ratio are.
38-116 Code 121 Powering Up Help - by AVSorrell - 07-17-2017, 08:12 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-17-2017, 08:21 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-17-2017, 09:47 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-18-2017, 08:57 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-18-2017, 12:05 PM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-19-2017, 09:08 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-30-2017, 02:49 PM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-30-2017, 08:10 PM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-31-2017, 08:42 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-31-2017, 01:27 PM
RE: 38-116 Code 121 Powering Up Help - by Chris h - 09-26-2017, 01:19 PM
Users browsing this thread: 13 Guest(s)
The speaker table error?
Philco 70 antenna lead
