Philco model 50
Hi
They are paper caps inside a bakelite housing. Non polarize. Typically but not all the time you will have two caps inside with two ends tied together connected to the chaiss ground though the mounting screw. The two ends will connect to the other two terminals on the bakelite block and thus making connections to the circuits in the radio. Please check diagram to make sure what the values are and how they connect to the set.
Philco model 50 - by Guest - 01-15-2010, 04:08 PM
Re: Philco model 50 - by Ron Ramirez - 01-15-2010, 05:58 PM
Re: Philco model 50 - by Guest - 01-15-2010, 07:00 PM
Re: Philco model 50 - by Carl Travis - 01-15-2010, 11:53 PM
Re: Philco model 50 - by Guest - 01-16-2010, 01:09 PM
Re: Philco model 50 - by Guest - 02-09-2010, 06:14 PM
Re: Philco model 50 - by 7estatdef - 02-09-2010, 07:06 PM
Re: Philco model 50 - by Guest - 02-09-2010, 07:42 PM
Re: Philco model 50 - by 7estatdef - 02-10-2010, 03:42 PM
Re: Philco model 50 - by Joe Rossi - 02-11-2010, 12:23 PM
Re: Philco model 50 - by Guest - 02-12-2010, 01:52 PM
Re: Philco model 50 - by 7estatdef - 02-12-2010, 09:33 PM
Re: Philco model 50 - by Guest - 02-13-2010, 09:37 AM
Re: Philco model 50 - by Jim Berg - 02-13-2010, 01:35 PM
