The (other) "P" word
FWIW, I much prefer the Scotchbrite pads over steel wool.
Another FWIW, maybe 'good' stripper is coming (back) to the market. Here I'm pretty much stuck buying local brands and they have historically been very weak. I bought some a few months ago that takes off poly almost as good as the older stuff took off lacquer. This stuff was pricy, $12.95/qt., nothing distinguishable on the label. Shop around!
The (other) "P" word - by TimC - 02-09-2010, 11:14 AM
Re: The (other) "P" word - by denver - 02-09-2010, 11:52 AM
Re: The (other) "P" word - by TimC - 02-09-2010, 01:56 PM
Re: The (other) "P" word - by 7estatdef - 02-09-2010, 06:49 PM
Re: The (other) "P" word - by codefox1 - 02-09-2010, 07:01 PM
Re: The (other) "P" word - by exray - 02-10-2010, 07:15 AM
Re: The (other) "P" word - by denver - 02-10-2010, 09:42 AM
Re: The (other) "P" word - by exray - 02-11-2010, 11:26 PM
Re: The (other) "P" word - by Ron Ramirez - 02-15-2010, 11:30 AM
Re: The (other) "P" word - by exray - 02-15-2010, 10:07 PM
Re: The (other) "P" word - by denver - 02-16-2010, 06:59 PM
Re: The (other) "P" word - by TimC - 02-16-2010, 09:44 PM
Re: The (other) "P" word - by denver - 02-16-2010, 11:17 PM
There are currently 5878 online users. [Complete List]
» 2 Member(s) | 5876 Guest(s)
