The (other) "P" word
Scotch brite pads work great helping strip. Done alot of this stuff nothing like steel wool for that slick as glass look.
If iam stripping a radio iwould take chassi , and speaker out. Can air off steel wool particles .
OH i pick up tooth brushes every time i find those hard to find left handed ones.
The (other) "P" word - by TimC - 02-09-2010, 11:14 AM
Re: The (other) "P" word - by denver - 02-09-2010, 11:52 AM
Re: The (other) "P" word - by TimC - 02-09-2010, 01:56 PM
Re: The (other) "P" word - by 7estatdef - 02-09-2010, 06:49 PM
Re: The (other) "P" word - by codefox1 - 02-09-2010, 07:01 PM
Re: The (other) "P" word - by exray - 02-10-2010, 07:15 AM
Re: The (other) "P" word - by denver - 02-10-2010, 09:42 AM
Re: The (other) "P" word - by exray - 02-11-2010, 11:26 PM
Re: The (other) "P" word - by Ron Ramirez - 02-15-2010, 11:30 AM
Re: The (other) "P" word - by exray - 02-15-2010, 10:07 PM
Re: The (other) "P" word - by denver - 02-16-2010, 06:59 PM
Re: The (other) "P" word - by TimC - 02-16-2010, 09:44 PM
Re: The (other) "P" word - by denver - 02-16-2010, 11:17 PM
There are currently 8830 online users. [Complete List]
» 1 Member(s) | 8829 Guest(s)
