band switch
Model 111 does not have a band switch - it receives AM only.
It sounds like you are describing the normal-maximum switch, since you say it has three connections.
These switches do get dirty and intermittent. Try cleaning it first with a good contact cleaner.
If that does not work, try WD-40.
If that does not work...it may require replacement. You will need an SPDT toggle switch. The only problem with replacements is that it is very difficult, if not impossible, to find an old-looking (it is commonly called "ball-bat") SPDT switch, and the new one will be obvious. Fortunately, since it mounts on top of the chassis, not easily seen, replacement will be better than a nonfunctional radio...
band switch - by denver - 02-10-2010, 10:00 AM
Re: band switch - by Ron Ramirez - 02-10-2010, 11:54 AM
Re: band switch - by denver - 02-10-2010, 12:07 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
