Nathan's Philco 118MX
I've been reading some more - it sounds like for the thick (1/16") unbacked veneer like I'm using it really needs a quite hard adhesive that won't 'creep' as the veneer expands/contracts. Apparently that's 'PPR' type glue - powdered pre-catalyzed resin. Sounds horrible! Icon_smile
I contacted https://www.joewoodworker.com and asked for recommendations - they replied with this product:
http://www.veneersupplies.com/products/U...-Glue.html
Unfortunately you have to buy a 5lb pail of it! And it only has a 1yr shelf life.
I think this is essentially the same thing, but available in smaller quantities, so I'm going to try that:
http://www.ptreeusa.com/gluing_brand_proglue.htm
Another consideration is that it requires >70 degrees Fahrenheit to bond. Not a problem in July - but here in the Pacific Northwest that's hard to come by much of the year.
Nathan's Philco 118MX - by Nathan Slingerland - 07-04-2017, 10:13 PM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 07-04-2017, 10:17 PM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 07-04-2017, 10:24 PM
RE: Nathan's Philco 118MX - by Ron Ramirez - 07-05-2017, 06:04 AM
RE: Nathan's Philco 118MX - by OldRestorer - 07-05-2017, 06:41 AM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 07-05-2017, 09:59 AM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 07-06-2017, 11:36 PM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 07-19-2017, 12:12 AM
RE: Nathan's Philco 118MX - by klondike98 - 07-19-2017, 08:05 AM
RE: Nathan's Philco 118MX - by OldRestorer - 07-19-2017, 08:24 AM
RE: Nathan's Philco 118MX - by Radioroslyn - 07-19-2017, 10:29 AM
RE: Nathan's Philco 118MX - by Ron Ramirez - 07-20-2017, 05:57 PM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 07-20-2017, 06:11 PM
RE: Nathan's Philco 118MX - by Bob Andersen - 07-21-2017, 05:40 PM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 07-21-2017, 08:16 PM
RE: Nathan's Philco 118MX - by OldRestorer - 07-23-2017, 12:13 PM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 08-04-2017, 10:43 PM
RE: Nathan's Philco 118MX - by OldRestorer - 08-05-2017, 11:22 AM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 08-05-2017, 12:00 PM
RE: Nathan's Philco 118MX - by klondike98 - 08-05-2017, 05:31 PM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 08-05-2017, 09:41 PM
RE: Nathan's Philco 118MX - by Nathan Slingerland - 08-06-2017, 06:33 PM
RE: Nathan's Philco 118MX - by Fred Taylor - 08-07-2017, 07:22 AM
Eico 232 VTVM Schematic
There are currently 6475 online users. [Complete List]
» 2 Member(s) | 6473 Guest(s)
