Peck & Hills Furniture Company
Thanks for the tips Arran, yeah if I'm going to keep cost down on this I'd better be sure about those tubes before I toss them. I use a recently calibrated Hickok 533, but I'll still make sure.
Peck & Hills Furniture Company - by lasurveyor - 07-16-2017, 09:40 PM
RE: Peck & Hills Furniture Company - by Arran - 07-20-2017, 09:55 PM
RE: Peck & Hills Furniture Company - by lasurveyor - 07-21-2017, 12:11 PM
RE: Peck & Hills Furniture Company - by Arran - 07-22-2017, 12:43 AM
RE: Peck & Hills Furniture Company - by Joe Rossi - 07-22-2017, 05:22 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
