116X Tuning cap removal
I got one out and my best guess is that it's 1/4 tall (above the chassis) 3/8 chassis hole and 3/16 center hole. So I came up w/this   http://www.renovatedradios.com/product.php?product=290
Tried ordering them but I couldn't finish because it would let me select a method of payment. Don't know if it is a separate operation.
Think I'm going to use some solder lugs instead if trying to solder to the 1/4" screw heads.
116X Tuning cap removal - by Radioroslyn - 07-21-2017, 03:43 PM
RE: 116X Tuning cap removal - by morzh - 07-21-2017, 04:14 PM
RE: 116X Tuning cap removal - by Radioroslyn - 07-21-2017, 04:54 PM
RE: 116X Tuning cap removal - by KCMike - 07-21-2017, 05:23 PM
RE: 116X Tuning cap removal - by Radioroslyn - 07-21-2017, 06:37 PM
RE: 116X Tuning cap removal - by KCMike - 07-21-2017, 07:13 PM
RE: 116X Tuning cap removal - by Radioroslyn - 09-08-2017, 10:07 AM
RE: 116X Tuning cap removal - by sam - 09-08-2017, 11:35 AM
RE: 116X Tuning cap removal - by Radioroslyn - 09-08-2017, 11:40 AM
RE: 116X Tuning cap removal - by sam - 09-08-2017, 11:43 AM
RE: 116X Tuning cap removal - by morzh - 09-08-2017, 01:50 PM
RE: 116X Tuning cap removal - by Radioroslyn - 09-08-2017, 05:23 PM
RE: 116X Tuning cap removal - by Radioroslyn - 09-22-2017, 06:09 PM
The speaker table error?
Philco 70 antenna lead
