My Antenna is Stuck!
A friend of mine in my club suggested this oil for lubrication on antenna or other radio parts, any one use it?
http://www.manventureoutpost.com/product...E3EALw_wcB
Apparently for firearms, but sounds good.
My Antenna is Stuck! - by Paul Philco322 - 07-20-2017, 10:54 AM
RE: My Antenna is Stuck! - by Phlogiston - 07-20-2017, 11:19 AM
RE: My Antenna is Stuck! - by morzh - 07-20-2017, 11:20 AM
RE: My Antenna is Stuck! - by Paul Philco322 - 07-20-2017, 12:16 PM
RE: My Antenna is Stuck! - by Paul Philco322 - 07-20-2017, 05:18 PM
RE: My Antenna is Stuck! - by sam - 07-20-2017, 08:17 PM
RE: My Antenna is Stuck! - by Paul Philco322 - 07-23-2017, 07:57 PM
RE: My Antenna is Stuck! - by OldRestorer - 07-23-2017, 09:04 PM
RE: My Antenna is Stuck! - by Eliot Ness - 07-24-2017, 08:35 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
