My Antenna is Stuck!
I'd say either Hoppes or ZoomSpout oil would be a good addition to have around.  You might be able to find one of them locally or on Amazon to save on shipping.
https://www.amazon.com/ounce-Zoom-spout-...pout+oiler
https://www.amazon.com/Hoppes-Lubricatin...hoppes+oil
Note: the ZoomSpout seems to come in a few different formulations, the link above is one I use for general lubrication, but I'm not sure if it is the same as Kirk uses.
My Antenna is Stuck! - by Paul Philco322 - 07-20-2017, 10:54 AM
RE: My Antenna is Stuck! - by Phlogiston - 07-20-2017, 11:19 AM
RE: My Antenna is Stuck! - by morzh - 07-20-2017, 11:20 AM
RE: My Antenna is Stuck! - by Paul Philco322 - 07-20-2017, 12:16 PM
RE: My Antenna is Stuck! - by Paul Philco322 - 07-20-2017, 05:18 PM
RE: My Antenna is Stuck! - by sam - 07-20-2017, 08:17 PM
RE: My Antenna is Stuck! - by Paul Philco322 - 07-23-2017, 07:57 PM
RE: My Antenna is Stuck! - by OldRestorer - 07-23-2017, 09:04 PM
RE: My Antenna is Stuck! - by Eliot Ness - 07-24-2017, 08:35 AM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 3181 online users. [Complete List]
» 4 Member(s) | 3177 Guest(s)
AvatarAvatarAvatarAvatar
