  • 1 Vote(s) - 1 Average
Philco 42-360 3rd.IF can (32-3640))
Got two answers. One connect a rf choke from the red to white wires then a small mica from the white to green wires. Or find a 455kc if output can and replace it or just the open winding.
http://philcoradio.com/phorum/showthread.php?tid=15651
Start reading at post 15.
RE: Philco 42-360 3rd.IF can (32-3640)) - by Radioroslyn - 07-24-2017, 05:22 PM
The speaker table error?
Philco 70 antenna lead
