53-1750 Alignment question
I will try it with the isolation transformer, I need to go out and buy one. Is there a particular brand of isolation transformer you like? Other than preventing a shock while working on the radio, is there any advantage to running it all the time with an isolation transformer? Thnks
53-1750 Alignment question - by ODPILOT - 07-24-2017, 05:53 PM
RE: 53-1750 Alignment question - by Radioroslyn - 07-24-2017, 06:47 PM
RE: 53-1750 Alignment question - by ODPILOT - 07-24-2017, 09:36 PM
RE: 53-1750 Alignment question - by morzh - 07-24-2017, 10:06 PM
RE: 53-1750 Alignment question - by Radioroslyn - 07-24-2017, 10:24 PM
RE: 53-1750 Alignment question - by klondike98 - 07-24-2017, 10:35 PM
RE: 53-1750 Alignment question - by ODPILOT - 07-27-2017, 08:41 AM
RE: 53-1750 Alignment question - by Radioroslyn - 07-27-2017, 10:11 AM
RE: 53-1750 Alignment question - by morzh - 07-27-2017, 10:34 AM
RE: 53-1750 Alignment question - by ODPILOT - 07-27-2017, 12:53 PM
RE: 53-1750 Alignment question - by Radioroslyn - 07-27-2017, 01:30 PM
The speaker table error?
Philco 70 antenna lead
