Philco Model 16B Cathedral
Hi Morzh,
Thanks for the info. I thought that I had seen something on changes and updates somewhere, I just couldn't remember where. I do remember reading your posts on rebuilding your 16B, but no matter what I put into the search, I was not able to find it until tonight.  Thanks
I did finally figure out the tone control caps that the guy on You Tube was talking about, Sunday morning.  I wish I had seen it first, as it would have saved a lot of time and head scratching.  I did finally figure out that the one Bakelite block, #80, as I recall, was shown in error in the info that I have on the bakelite blocks.  Even though I now have it wired per the schematic, it does not have any real change in how things sound.  I am going to have to noodle on the changes sheets and see if I can figure out what is going on.  The #80 Bakelite is not shown on my parts layout though.  It took a little while to figure that one out too.  I think just getting away from it for a little while helps bring things to light.  It will take a while to digest what is going on with the changes to the volume control too.
Again, thanks for your help and guidance.
Chris H
N9WHH
Philco Model 16B Cathedral - by Chris h - 07-04-2017, 01:08 PM
RE: Philco Model 16B Cathedral - by morzh - 07-04-2017, 04:30 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-05-2017, 01:10 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-14-2017, 08:20 AM
RE: Philco Model 16B Cathedral - by morzh - 07-14-2017, 08:45 AM
RE: Philco Model 16B Cathedral - by Chris h - 07-14-2017, 05:14 PM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-17-2017, 11:29 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-18-2017, 08:25 AM
RE: Philco Model 16B Cathedral - by morzh - 07-18-2017, 08:53 AM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-18-2017, 05:08 PM
RE: Philco Model 16B Cathedral - by morzh - 07-18-2017, 05:34 PM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-18-2017, 07:22 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-21-2017, 08:36 AM
RE: Philco Model 16B Cathedral - by morzh - 07-21-2017, 09:06 AM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-21-2017, 04:52 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-24-2017, 01:06 PM
RE: Philco Model 16B Cathedral - by morzh - 07-24-2017, 01:11 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-24-2017, 10:37 PM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-25-2017, 01:05 AM
RE: Philco Model 16B Cathedral - by klondike98 - 07-25-2017, 08:11 AM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-25-2017, 07:15 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-26-2017, 08:10 AM
RE: Philco Model 16B Cathedral - by morzh - 07-26-2017, 10:32 AM
RE: Philco Model 16B Cathedral - by Chris h - 07-27-2017, 01:33 PM
RE: Philco Model 16B Cathedral - by Ron Ramirez - 07-29-2017, 07:26 AM
RE: Philco Model 16B Cathedral - by Chris h - 08-01-2017, 01:28 PM
RE: Philco Model 16B Cathedral - by morzh - 08-01-2017, 04:34 PM
RE: Philco Model 16B Cathedral - by morzh - 08-01-2017, 08:33 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-02-2017, 08:08 AM
RE: Philco Model 16B Cathedral - by Sean - 08-02-2017, 08:54 AM
RE: Philco Model 16B Cathedral - by Chris h - 08-02-2017, 01:08 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-03-2017, 01:38 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-04-2017, 10:27 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-08-2017, 01:21 PM
RE: Philco Model 16B Cathedral - by Radioroslyn - 08-08-2017, 01:28 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-08-2017, 10:18 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-25-2017, 01:30 PM
RE: Philco Model 16B Cathedral - by 462ron - 08-25-2017, 01:50 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-26-2017, 08:57 PM
The speaker table error?
Philco 70 antenna lead
