Needing lots of help Restoring a Philco Model 48-1262
<  Second, there is a good copy of the Service Bulletin for your model at the Audiophool site.
[url=https://www.antiqueradio.org/begin.htm][/url]
Methinks Bob meant to link to this  http://www.audiophool.com/Philco.html
Look under 1948 for your info as Philco model numbers, the 1st two digits indicate the model year in which it was made. It is true from 1937- thru abt 1954. At this point the model numbers start w/a letter. The info found is the same as I posted just a different site.
Bob and his fancy links[Image: http://philcoradio.com/phorum/images/smi...n_cool.gif]
RE: Needing lots of help Restoring a Philco Model 48-1262 - by Radioroslyn - 07-25-2017, 09:08 AM
The speaker table error?
Philco 70 antenna lead
