  • 1 Vote(s) - 5 Average
38-39 Vibrator Power Supply Replacement
What else can I try to eliminate this RF noise?
RE: 38-39 Vibrator Power Supply Replacement - by Olskuul - 07-26-2017, 11:47 AM
The speaker table error?
Philco 70 antenna lead
