  • 1 Vote(s) - 5 Average
38-39 Vibrator Power Supply Replacement
You could try ferrite beads on output wires.
RE: 38-39 Vibrator Power Supply Replacement - by morzh - 07-26-2017, 08:56 PM
The speaker table error?
Philco 70 antenna lead
