53-1750 Alignment question
Wow, OK got it.. Thanks
53-1750 Alignment question - by ODPILOT - 07-24-2017, 05:53 PM
RE: 53-1750 Alignment question - by Radioroslyn - 07-24-2017, 06:47 PM
RE: 53-1750 Alignment question - by ODPILOT - 07-24-2017, 09:36 PM
RE: 53-1750 Alignment question - by morzh - 07-24-2017, 10:06 PM
RE: 53-1750 Alignment question - by Radioroslyn - 07-24-2017, 10:24 PM
RE: 53-1750 Alignment question - by klondike98 - 07-24-2017, 10:35 PM
RE: 53-1750 Alignment question - by ODPILOT - 07-27-2017, 08:41 AM
RE: 53-1750 Alignment question - by Radioroslyn - 07-27-2017, 10:11 AM
RE: 53-1750 Alignment question - by morzh - 07-27-2017, 10:34 AM
RE: 53-1750 Alignment question - by ODPILOT - 07-27-2017, 12:53 PM
RE: 53-1750 Alignment question - by Radioroslyn - 07-27-2017, 01:30 PM
The speaker table error?
Philco 70 antenna lead
