Please ID radio
No expert here but it looks like a home made job, especially that grille work looks like it's from an old radiator enclosure!
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Please ID radio - by vecher - 07-28-2017, 11:20 PM
RE: Please ID radio - by 462ron - 07-29-2017, 09:02 AM
RE: Please ID radio - by OldRestorer - 07-29-2017, 04:12 PM
RE: Please ID radio - by WallaceRoger - 07-29-2017, 07:04 PM
RE: Please ID radio - by WallaceRoger - 07-30-2017, 11:00 AM
RE: Please ID radio - by Scott D - 08-20-2017, 08:58 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
