38-116 Code 121 Powering Up Help
#35
Okay - I bypassed the CL-90 and am up to 110 vac across the primaries and at the switch - but still no reception across the bands.
Andy Sorrell
Palmyra, Virginia
38-116 Code 121 Powering Up Help - by AVSorrell - 07-17-2017, 08:12 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-17-2017, 08:21 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-17-2017, 09:47 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-18-2017, 08:57 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-18-2017, 12:05 PM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-19-2017, 09:08 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-30-2017, 02:49 PM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-30-2017, 08:10 PM
RE: 38-116 Code 121 Powering Up Help - by AVSorrell - 07-31-2017, 07:59 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-31-2017, 08:42 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-31-2017, 01:27 PM
RE: 38-116 Code 121 Powering Up Help - by Chris h - 09-26-2017, 01:19 PM
Users browsing this thread: 19 Guest(s)
The speaker table error?
Philco 70 antenna lead
