38-116 Code 121 Powering Up Help
#41
Thanks for the ideas! Good news is that I tuned my signal generator to 470kc and connected it to the grid caps of 1st and 2nd IFs 6K7s and heard a signal loud and clear from the speaker. I also heard a signal on the 6k7 RF grid cap and one on the 6L7 mixer on the rf deck. I did not hear a signal on any other grid caps. I tuned my 38-116 to 1000 kc and another radio to 1470 kc and rocked the dial and did not hear anything from my 38-116. I have some bad tubes I can make a extender as I trouble shoot the rf section - good idea!!
Andy Sorrell
Palmyra, Virginia
38-116 Code 121 Powering Up Help - by AVSorrell - 07-17-2017, 08:12 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-17-2017, 08:21 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-17-2017, 09:47 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-18-2017, 08:57 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-18-2017, 12:05 PM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-19-2017, 09:08 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-30-2017, 02:49 PM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-30-2017, 08:10 PM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-31-2017, 08:42 AM
RE: 38-116 Code 121 Powering Up Help - by morzh - 07-31-2017, 01:27 PM
RE: 38-116 Code 121 Powering Up Help - by AVSorrell - 08-01-2017, 07:52 AM
RE: 38-116 Code 121 Powering Up Help - by Chris h - 09-26-2017, 01:19 PM
Users browsing this thread: 18 Guest(s)
The speaker table error?
Philco 70 antenna lead
