Philco 38-690 electronics restoration.
#86
I need some break.
Not sure why I am being punished but both transformers came.....incorrect.
I will call them tomorrow, and will or will not publish the results pending their willingness to remedy the situation.
It took 1-1/2 month and.....this.
Sigh.
Philco 38-690 electronics restoration. - by morzh - 04-12-2017, 08:19 PM
RE: Philco 38-690 electronics restoration. - by morzh - 08-01-2017, 08:32 PM
Users browsing this thread: 15 Guest(s)
The speaker table error?
Philco 70 antenna lead
