Chassis 39-3A1 wiring
Hi Steve and welcome,
> There are two wires that have come un-soldered.
Geez and I thought it was hot in PA!!
My best guess is that those wire are the antenna and ground for the set. These weren't solder to anything to start with.
Does the set play when it plugged in, turned on, and an antenna is connected??
Chassis 39-3A1 wiring - by slink - 08-01-2017, 08:15 PM
RE: Chassis 39-3A1 wiring - by Radioroslyn - 08-01-2017, 11:47 PM
RE: Chassis 39-3A1 wiring - by klondike98 - 08-03-2017, 09:21 AM
The speaker table error?
Philco 70 antenna lead
