Condenser working voltages?
It is a 37-9.
I have also been having a problem sourcing the 1000V (or more) 30-4469 that is in there. What are you guys using for some of the high voltage caps? and where are you getting them, Mouser does not have any mylars of that high a working voltage... do you have a mouser number for what you are using?
Kurt
Condenser working voltages? - by wu8v - 02-14-2010, 05:10 PM
Re: Condenser working voltages? - by exray - 02-14-2010, 10:04 PM
Re: Condenser working voltages? - by wu8v - 02-14-2010, 10:12 PM
Re: Condenser working voltages? - by exray - 02-14-2010, 10:19 PM
Re: Condenser working voltages? - by wu8v - 02-14-2010, 10:27 PM
Re: Condenser working voltages? - by exray - 02-14-2010, 10:32 PM
Re: Condenser working voltages? - by wu8v - 02-14-2010, 10:57 PM
Re: Condenser working voltages? - by Ron Ramirez - 02-15-2010, 11:11 AM
Re: Condenser working voltages? - by exray - 02-15-2010, 09:55 PM
Re: Condenser working voltages? - by Jim Berg - 02-17-2010, 02:44 PM
Re: Condenser working voltages? - by Alan Douglas - 02-17-2010, 11:31 PM
Re: Condenser working voltages? - by 37-670 - 04-11-2010, 10:06 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
