Philco Model 16B Cathedral
#39
Thanks Nathan. I have one on its way.
I installed the new tuning dial, shadow meter and the rest of the tuning mechanism, last night. Pretty much as expected; the shadow meter leaves a little to be desired. It will do, until I can find another one. I still need to play with the lamp alignment behind the tuning dial. My lamp leads are too short, and it is pulling the lamp in the BC position. A minor detail, I think.
Now to the RF/IF alignment, and need to do some speaker repairs. It rattles a little. Now I see some tears in the rolled suspension that I had not spotted before. Even with the occasional rattle it sounds pretty good.
Chris H
N9WHH
Philco Model 16B Cathedral - by Chris h - 07-04-2017, 01:08 PM
RE: Philco Model 16B Cathedral - by morzh - 07-04-2017, 04:30 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-05-2017, 01:10 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-14-2017, 08:20 AM
RE: Philco Model 16B Cathedral - by morzh - 07-14-2017, 08:45 AM
RE: Philco Model 16B Cathedral - by Chris h - 07-14-2017, 05:14 PM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-17-2017, 11:29 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-18-2017, 08:25 AM
RE: Philco Model 16B Cathedral - by morzh - 07-18-2017, 08:53 AM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-18-2017, 05:08 PM
RE: Philco Model 16B Cathedral - by morzh - 07-18-2017, 05:34 PM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-18-2017, 07:22 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-21-2017, 08:36 AM
RE: Philco Model 16B Cathedral - by morzh - 07-21-2017, 09:06 AM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-21-2017, 04:52 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-24-2017, 01:06 PM
RE: Philco Model 16B Cathedral - by morzh - 07-24-2017, 01:11 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-24-2017, 10:37 PM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-25-2017, 01:05 AM
RE: Philco Model 16B Cathedral - by klondike98 - 07-25-2017, 08:11 AM
RE: Philco Model 16B Cathedral - by Stall-U-Rated - 07-25-2017, 07:15 PM
RE: Philco Model 16B Cathedral - by Chris h - 07-26-2017, 08:10 AM
RE: Philco Model 16B Cathedral - by morzh - 07-26-2017, 10:32 AM
RE: Philco Model 16B Cathedral - by Chris h - 07-27-2017, 01:33 PM
RE: Philco Model 16B Cathedral - by Ron Ramirez - 07-29-2017, 07:26 AM
RE: Philco Model 16B Cathedral - by Chris h - 08-01-2017, 01:28 PM
RE: Philco Model 16B Cathedral - by morzh - 08-01-2017, 04:34 PM
RE: Philco Model 16B Cathedral - by morzh - 08-01-2017, 08:33 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-02-2017, 08:08 AM
RE: Philco Model 16B Cathedral - by Sean - 08-02-2017, 08:54 AM
RE: Philco Model 16B Cathedral - by Chris h - 08-02-2017, 01:08 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-03-2017, 01:38 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-04-2017, 10:27 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-08-2017, 01:21 PM
RE: Philco Model 16B Cathedral - by Radioroslyn - 08-08-2017, 01:28 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-08-2017, 10:18 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-25-2017, 01:30 PM
RE: Philco Model 16B Cathedral - by 462ron - 08-25-2017, 01:50 PM
RE: Philco Model 16B Cathedral - by Chris h - 08-26-2017, 08:57 PM
Users browsing this thread: 17 Guest(s)
The speaker table error?
Philco 70 antenna lead
