Transitone TH 4
http://www.nostalgiaair.org/PagesByModel...014241.pdf
Enjoy,
-Bill
Transitone TH 4 - by oakdust - 02-14-2010, 07:25 PM
Re: Transitone TH 4 - by exray - 02-14-2010, 10:48 PM
Re: Transitone TH 4 - by oakdust - 02-15-2010, 11:41 AM
Re: Transitone TH 4 - by Ron Ramirez - 02-15-2010, 11:42 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
