Model number for Freshman mini tombstone
This is the only Belmont I could find with four tubes, one of them being an 80. Thoughts?
http://www.nostalgiaair.org/pagesbymodel...002053.pdf
Greg
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
