Silvertone 4588 refinish
Beautiful work! I really like that era of Silvertone radios.
Silvertone 4588 refinish - by Fred Taylor - 08-07-2017, 07:46 AM
RE: Silvertone 4588 refinish - by Fred Taylor - 08-07-2017, 07:51 AM
RE: Silvertone 4588 refinish - by RadioSvit - 08-07-2017, 08:35 AM
RE: Silvertone 4588 refinish - by Crist Rigotti - 08-08-2017, 12:48 AM
RE: Silvertone 4588 refinish - by WallaceRoger - 08-08-2017, 09:56 AM
RE: Silvertone 4588 refinish - by Steve Davis - 08-08-2017, 09:59 AM
RE: Silvertone 4588 refinish - by Nathan Slingerland - 08-08-2017, 10:28 AM
RE: Silvertone 4588 refinish - by morzh - 08-08-2017, 10:42 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
