The (other) "P" word
Polyurethane, UGH. When I was young and foolish I used to use the stuff. Then I learned better and began to use lacquer, which is what was used originally on our radio cabinets.
Lacquer dries faster and is easier to correct if you mess up.
Bill, what is the brand name of the stripper you found that removes polyurethane?
The (other) "P" word - by TimC - 02-09-2010, 11:14 AM
Re: The (other) "P" word - by denver - 02-09-2010, 11:52 AM
Re: The (other) "P" word - by TimC - 02-09-2010, 01:56 PM
Re: The (other) "P" word - by 7estatdef - 02-09-2010, 06:49 PM
Re: The (other) "P" word - by codefox1 - 02-09-2010, 07:01 PM
Re: The (other) "P" word - by exray - 02-10-2010, 07:15 AM
Re: The (other) "P" word - by denver - 02-10-2010, 09:42 AM
Re: The (other) "P" word - by exray - 02-11-2010, 11:26 PM
Re: The (other) "P" word - by Ron Ramirez - 02-15-2010, 11:30 AM
Re: The (other) "P" word - by exray - 02-15-2010, 10:07 PM
Re: The (other) "P" word - by denver - 02-16-2010, 06:59 PM
Re: The (other) "P" word - by TimC - 02-16-2010, 09:44 PM
Re: The (other) "P" word - by denver - 02-16-2010, 11:17 PM
Philco 91 Tuning Condenser
There are currently 10098 online users. [Complete List]
» 2 Member(s) | 10096 Guest(s)
