Power transformer testing
What I meant by "continuity" is just the simple go/no-go feature of my multimeter. With the selector knob in the ohms measurement position, I have the option of two "modes" with a selector button. One mode displays the actual measured resistance in ohms on the meter readout, the other mode simply displays "open" or "shrt" on the readout, with a short-circuit indication accompanied by an audible beep tone.
Is this a bad evaluation technique? Should I stick solely to the ohms readout mode or should I apply voltage to the transformer (variac) and measure the output voltage, which was my original question.
Power transformer testing - by mark123 - 08-08-2017, 01:00 PM
RE: Power transformer testing - by morzh - 08-08-2017, 01:08 PM
RE: Power transformer testing - by Radioroslyn - 08-08-2017, 01:23 PM
RE: Power transformer testing - by mark123 - 08-09-2017, 09:41 AM
RE: Power transformer testing - by morzh - 08-09-2017, 10:53 AM
RE: Power transformer testing - by mark123 - 08-09-2017, 12:34 PM
RE: Power transformer testing - by morzh - 08-09-2017, 01:08 PM
The speaker table error?
Philco 70 antenna lead
