Philco 20A - Electronic Restoration Questions
Into the garbage.
Greg
RE: Philco 20A - Old cap can caps - by morzh - 08-09-2017, 08:03 PM
RE: Philco 20A - Old cap can caps - by WallaceRoger - 08-09-2017, 09:54 PM
Capacitors for Philco Model 20 - by MrGrnEgz - 08-09-2017, 11:12 PM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-10-2017, 09:50 AM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-10-2017, 02:46 PM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-10-2017, 03:27 PM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-11-2017, 05:26 AM
Model 20A Frequency Indicator - by MrGrnEgz - 08-11-2017, 05:38 AM
Model 20A Power Cord - by MrGrnEgz - 08-12-2017, 01:18 PM
RE: Model 20A Power Cord - by Radioroslyn - 08-12-2017, 01:28 PM
Model 20A Speaker Cone Repair - by MrGrnEgz - 08-13-2017, 09:41 PM
AUX audio input for model 20A - by MrGrnEgz - 08-13-2017, 10:54 PM
RE: Model 20A Speaker Cone Repair - by MrGrnEgz - 08-14-2017, 08:50 AM
RE: Model 20A Speaker Cone Repair - by morzh - 08-14-2017, 04:48 PM
The speaker table error?
Philco 70 antenna lead
