Philco 20A - Electronic Restoration Questions
I bought some large assortments of 630v film capacitors and resistor assortments on ebay, they usually have free shipping, too. If you go that route, be sure you check where they're shipping from, a lot of them will be from Hong Kong and if so, you'll be waiting a couple weeks for them. There are several there that ship from within the US though.
The original resistors in the 20 are 1 watt, I only had 1/2 watt so I doubled up on resistance and ran them parallel to get back to 1 watt at correct resistance spec.
Greg
RE: Philco 20A - Old cap can caps - by morzh - 08-09-2017, 08:03 PM
Capacitors for Philco Model 20 - by MrGrnEgz - 08-09-2017, 11:12 PM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-10-2017, 09:50 AM
RE: Capacitors for Philco Model 20 - by WallaceRoger - 08-10-2017, 11:26 AM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-10-2017, 02:46 PM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-10-2017, 03:27 PM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-11-2017, 05:26 AM
Model 20A Frequency Indicator - by MrGrnEgz - 08-11-2017, 05:38 AM
Model 20A Power Cord - by MrGrnEgz - 08-12-2017, 01:18 PM
RE: Model 20A Power Cord - by Radioroslyn - 08-12-2017, 01:28 PM
Model 20A Speaker Cone Repair - by MrGrnEgz - 08-13-2017, 09:41 PM
AUX audio input for model 20A - by MrGrnEgz - 08-13-2017, 10:54 PM
RE: Model 20A Speaker Cone Repair - by MrGrnEgz - 08-14-2017, 08:50 AM
RE: Model 20A Speaker Cone Repair - by morzh - 08-14-2017, 04:48 PM
The speaker table error?
Philco 70 antenna lead
