Philco Model 20 ?
Ok Thanks for the input..He has others in a different shed in back of the one we were in.. Probably around 7 or 8 .. Along with a lot of Jukeboxes..
Don't know want kind .. Next time up there I will look...
Skip...
Philco Model 20 ? - by vecher - 08-10-2017, 11:30 AM
RE: Philco Model 20 ? - by morzh - 08-10-2017, 12:02 PM
RE: Philco Model 20 ? - by OldRestorer - 08-10-2017, 12:02 PM
RE: Philco Model 20 ? - by WallaceRoger - 08-10-2017, 12:36 PM
RE: Philco Model 20 ? - by vecher - 08-10-2017, 12:57 PM
RE: Philco Model 20 ? - by Nathan Slingerland - 08-10-2017, 12:58 PM
RE: Philco Model 20 ? - by morzh - 08-10-2017, 01:06 PM
RE: Philco Model 20 ? - by vecher - 08-10-2017, 01:20 PM
RE: Philco Model 20 ? - by morzh - 08-10-2017, 02:04 PM
RE: Philco Model 20 ? - by vecher - 08-10-2017, 02:16 PM
RE: Philco Model 20 ? - by sam - 08-10-2017, 08:17 PM
RE: Philco Model 20 ? - by morzh - 08-10-2017, 08:26 PM
RE: Philco Model 20 ? - by OldRestorer - 08-10-2017, 09:02 PM
RE: Philco Model 20 ? - by Electrothaumaturgist - 10-23-2017, 01:41 PM
RE: Philco Model 20 - by vecher - 02-13-2018, 12:22 AM
RE: Philco Model 20 ? - by PhilcoPhan1936 - 02-13-2018, 01:08 AM
RE: Philco Model 20 ? - by Ron Ramirez - 02-13-2018, 06:45 AM
RE: Philco Model 20 ? - by vecher - 02-13-2018, 04:41 PM
RE: Philco Model 20 ? - by Radioroslyn - 02-13-2018, 05:29 PM
RE: Philco Model 20 ? - by vecher - 02-14-2018, 12:16 AM
RE: Philco Model 20 ? - by Radioroslyn - 02-14-2018, 12:24 AM
RE: Philco Model 20 ? - by vecher - 02-14-2018, 01:18 AM
RE: Philco Model 20 ? - by WallaceRoger - 02-14-2018, 04:24 PM
RE: Philco Model 20 ? - by vecher - 02-14-2018, 04:42 PM
RE: Philco Model 20 ? - by morzh - 02-14-2018, 04:54 PM
RE: Philco Model 20 ? - by vecher - 02-14-2018, 04:59 PM
RE: Philco Model 20 ? - by Radioroslyn - 02-14-2018, 05:16 PM
RE: Philco Model 20 ? - by vecher - 02-14-2018, 07:58 PM
There are currently 9721 online users. [Complete List]
» 3 Member(s) | 9718 Guest(s)
