Philco 20A - Electronic Restoration Questions
...actually the 20-A was also sold in the USA as there were some areas (parts of NY state as an example) that still had 25 cycle AC in 1930.
It seems a majority of Canada was on 25 cycle AC early on, but they had areas with 60 cycle AC as well. A Canadian-made Philco will have a metal tag instead of a paper sticker and will plainly state "PHILCO PRODUCTS LTD. TORONTO, CANADA" on it.
RE: Philco 20A - Old cap can caps - by morzh - 08-09-2017, 08:03 PM
Capacitors for Philco Model 20 - by MrGrnEgz - 08-09-2017, 11:12 PM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-10-2017, 09:50 AM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-10-2017, 02:46 PM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-10-2017, 03:27 PM
RE: Capacitors for Philco Model 20 - by MrGrnEgz - 08-11-2017, 05:26 AM
Model 20A Frequency Indicator - by MrGrnEgz - 08-11-2017, 05:38 AM
RE: Capacitors for Philco Model 20 - by Ron Ramirez - 08-11-2017, 06:23 AM
Model 20A Power Cord - by MrGrnEgz - 08-12-2017, 01:18 PM
RE: Model 20A Power Cord - by Radioroslyn - 08-12-2017, 01:28 PM
Model 20A Speaker Cone Repair - by MrGrnEgz - 08-13-2017, 09:41 PM
AUX audio input for model 20A - by MrGrnEgz - 08-13-2017, 10:54 PM
RE: Model 20A Speaker Cone Repair - by MrGrnEgz - 08-14-2017, 08:50 AM
RE: Model 20A Speaker Cone Repair - by morzh - 08-14-2017, 04:48 PM
The speaker table error?
Philco 70 antenna lead
