Condenser working voltages?
Ron Ramirez Wrote:As a general rule, you can replace nearly all paper caps with new ones rated at 600 or 630 VDC. .
I do as well. Not much point in stocking 200, 400, etc volts. The 630v are only a few pennies more and it would cost me a whole nuther cabinet to store a bunch of smaller voltages that might not get much use. Same with resistors. I normally buy 1 watters for general use.
Condenser working voltages? - by wu8v - 02-14-2010, 05:10 PM
Re: Condenser working voltages? - by exray - 02-14-2010, 10:04 PM
Re: Condenser working voltages? - by wu8v - 02-14-2010, 10:12 PM
Re: Condenser working voltages? - by exray - 02-14-2010, 10:19 PM
Re: Condenser working voltages? - by wu8v - 02-14-2010, 10:27 PM
Re: Condenser working voltages? - by exray - 02-14-2010, 10:32 PM
Re: Condenser working voltages? - by wu8v - 02-14-2010, 10:57 PM
Re: Condenser working voltages? - by Ron Ramirez - 02-15-2010, 11:11 AM
Re: Condenser working voltages? - by exray - 02-15-2010, 09:55 PM
Re: Condenser working voltages? - by Jim Berg - 02-17-2010, 02:44 PM
Re: Condenser working voltages? - by Alan Douglas - 02-17-2010, 11:31 PM
Re: Condenser working voltages? - by 37-670 - 04-11-2010, 10:06 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
