Philco 90 Arch Veneer Crack
I think it's actually called Paldao, I'm not sure if Australian Walnut is the same as orientalwood which is what Paldao is, I have some Australian walnut veneer and it looks more like ribbon mahogany (stripes) other then the greyish brown colour.. I don't believe it's that expensive either, Paldao is a huge, fast growing, tropical tree in New Guinea and the Philippines, so don't think the wood is particularly rare nor expensive. Have a look on fleabay for some.
Philco 90 Arch Veneer Crack - by louhaskell - 08-02-2017, 09:35 AM
RE: Philco 90 Arch Veneer Crack - by OldRestorer - 08-02-2017, 04:45 PM
RE: Philco 90 Arch Veneer Crack - by Arran - 08-12-2017, 03:07 AM
RE: Philco 90 Arch Veneer Crack - by Scott D - 08-17-2017, 10:53 AM
Eico 232 VTVM Schematic
There are currently 6477 online users. [Complete List]
» 1 Member(s) | 6476 Guest(s)
