The (other) "P" word
I used Stripeze. Poly was thin.
Restained cabinet now it needs a finish coat.
Used to use Tung-seal on tables...
Any ideas or thoughts?
tim
The (other) "P" word - by TimC - 02-09-2010, 11:14 AM
Re: The (other) "P" word - by denver - 02-09-2010, 11:52 AM
Re: The (other) "P" word - by TimC - 02-09-2010, 01:56 PM
Re: The (other) "P" word - by 7estatdef - 02-09-2010, 06:49 PM
Re: The (other) "P" word - by codefox1 - 02-09-2010, 07:01 PM
Re: The (other) "P" word - by exray - 02-10-2010, 07:15 AM
Re: The (other) "P" word - by denver - 02-10-2010, 09:42 AM
Re: The (other) "P" word - by exray - 02-11-2010, 11:26 PM
Re: The (other) "P" word - by Ron Ramirez - 02-15-2010, 11:30 AM
Re: The (other) "P" word - by exray - 02-15-2010, 10:07 PM
Re: The (other) "P" word - by denver - 02-16-2010, 06:59 PM
Re: The (other) "P" word - by TimC - 02-16-2010, 09:44 PM
Re: The (other) "P" word - by denver - 02-16-2010, 11:17 PM
Philco 91 Tuning Condenser
There are currently 9816 online users. [Complete List]
» 2 Member(s) | 9814 Guest(s)
