Switchable AUX Input
don't want to tell you --hope you see this,,,----about ,,that 1 strand of copper ,,,on bottom terminal,,really close to the middle terminal,,,,cut or re-insert into terminal hole,,,and solder----in #2 picture,,,,SORRY-----CHEERS
Switchable AUX Input - by Tgace459 - 08-14-2017, 06:22 PM
RE: Switchable AUX Input - by Kenneth F. Besso Jr. - 08-14-2017, 06:47 PM
RE: Switchable AUX Input - by Tgace459 - 08-14-2017, 06:53 PM
The speaker table error?
Philco 70 antenna lead
