ID on this one tuber...?
Obtw I forgot the ant wire, it's the long white that is going diagonally across the bottom of the chassis.
ID on this one tuber...? - by klondike98 - 08-15-2017, 07:30 PM
RE: ID on this one tuber...? - by WallaceRoger - 08-15-2017, 08:06 PM
RE: ID on this one tuber...? - by Paul Philco322 - 08-15-2017, 09:48 PM
RE: ID on this one tuber...? - by Radioroslyn - 08-16-2017, 04:30 PM
RE: ID on this one tuber...? - by klondike98 - 08-17-2017, 01:03 AM
RE: ID on this one tuber...? - by Radioroslyn - 08-17-2017, 11:26 AM
RE: ID on this one tuber...? - by 462ron - 08-17-2017, 04:47 PM
RE: ID on this one tuber...? - by Arran - 08-17-2017, 06:34 PM
RE: ID on this one tuber...? - by Radioroslyn - 08-17-2017, 08:00 PM
RE: ID on this one tuber...? - by WallaceRoger - 08-17-2017, 08:35 PM
RE: ID on this one tuber...? - by klondike98 - 08-18-2017, 12:13 PM
RE: ID on this one tuber...? - by palegreenthumb - 08-18-2017, 11:39 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6643 online users. [Complete List]
» 1 Member(s) | 6642 Guest(s)
