47-1227 Output transformer
I did not look the set up and see if that is the correct part number for the original. If it is a replacement those resistance reading could be OK. Does the unit smell burned? Also measure between primary and core and see if shorted to core. The set probably has leaky caps and may have drawn too much current and overheated the output transformer. May have damaged the power transformer also.
47-1227 Output transformer - by keith49vj3 - 02-15-2010, 10:38 PM
Re: 47-1227 Output transformer - by Jim Berg - 02-17-2010, 02:34 PM
Re: 47-1227 Output transformer - by Ron Ramirez - 02-17-2010, 04:15 PM
Re: 47-1227 Output transformer - by keith49vj3 - 02-17-2010, 08:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
