Crosley Bandbox 601 / What could go wrong??
Don't think I can't save the pot metal parts there too far gone. The rotors and stators are both badly warped along with the front mount. I do have a plan. I'm busy prototyping my idea and trying  it for size and fit. Synchronization and dial alignment is still being figured out.
The original copper bands are a little too short so I've been trying a few other materials to replicate the bands only a little longer. The trouble is it's been hard to cut a thin strip and keeping it straight, starts out ok end up being abt half the proper width when I get to the far end. It has a tendency to curl getting it to lay flat during the cutting process is tricky. Have to work on making a couple of jigs for straighter cut and centering the hole for the alignment pin.
I thought about varactor diodes but couldn't find one @ 350 or so mmf.
Maybe some wood pieces, some hinges, saran wrap, and sheet aluminum? Well it is a Crosley!
Haven't done any checking on the electronics side of things yet.
RE: What could go wrong??? - by OldRestorer - 08-22-2017, 06:00 PM
RE: What could go wrong??? - by Radioroslyn - 08-22-2017, 06:05 PM
RE: What could go wrong??? - by sam - 08-22-2017, 09:15 PM
RE: What could go wrong??? - by OldRestorer - 08-22-2017, 10:36 PM
RE: What could go wrong??? - by sam - 08-22-2017, 11:53 PM
RE: What could go wrong??? - by Eliot Ness - 08-23-2017, 08:41 AM
RE: What could go wrong??? - by Radioroslyn - 08-23-2017, 12:31 PM
RE: What could go wrong??? - by morzh - 08-23-2017, 12:51 PM
RE: What could go wrong??? - by klondike98 - 08-23-2017, 01:20 PM
RE: What could go wrong??? - by WallaceRoger - 08-23-2017, 02:25 PM
RE: What could go wrong??? - by Radioroslyn - 08-23-2017, 02:46 PM
RE: What could go wrong??? - by Radioroslyn - 08-23-2017, 06:32 PM
RE: What could go wrong??? - by OldRestorer - 08-23-2017, 07:36 PM
RE: What could go wrong??? - by WallaceRoger - 08-24-2017, 10:05 AM
There are currently 9953 online users. [Complete List]
» 3 Member(s) | 9950 Guest(s)
