Green eye tube won't turn green!
On Zeniths the 1M resistor that is usually located inside the socket often is open.
One way of replacing it without opening the socket (which is backelite and appears to already have cracks so opening it almost guarantees it won't survive it) is the way I did it for my Zenith 9S262.
You could find the topic, from, I think, year 2012.
In essence, I took a surface mount 0603 resistor, which is small and flat, soldered two thin strands of wire to each end, threaded them in the appropriate pins, laying resistor flat on the surface and re-insert the tube. The power dissipation is negligible so this works just fine.
Found it, here it is.
http://philcoradio.com/phorum/showthread...th+9-s-262
The photos are on the last page of the thread.
RE: Green eye tube won't turn green! - by morzh - 08-25-2017, 09:09 AM
RE: Green eye tube won't turn green! - by morzh - 08-26-2017, 07:47 AM
RE: Green eye tube won't turn green! - by morzh - 12-27-2017, 06:11 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4763 online users. [Complete List]
» 2 Member(s) | 4761 Guest(s)
