New chassis washers for a Philco 89
I did not fix 89.
But.
How about a dab of some glue to hold them in place while chassis is being pushed in?
RE: New chassis washers for a Philco 89 - by morzh - 08-25-2017, 07:02 PM
The speaker table error?
Philco 70 antenna lead
