38-1 121A run2 #4
yes, I want to get as much literature on this radio as I can, as it seems like it'll be a nice one if I can get that finish cleaned up. I guess the lacquer is peeling. The dial glass is there, but needs to be buffed back up. The top of the chassis looks unmolested. I see that there's not much info on here on that particular model for some reason. Which chassis would most closely match the 38-1 so that I can apply the same repairs to mine? And also, what does that "A" in code 121A signify, and would I need a revised schematic? Well, I'm going to take a deep breath and attempt to pull that dial face without breaking it. Any last minute pointers? Wish me luck... Icon_shifty
38-1 121A run2 #4 - by Electrothaumaturgist - 08-28-2017, 07:57 PM
RE: 38-1 121A run2 #4 - by morzh - 08-28-2017, 08:50 PM
RE: 38-1 121A run2 #4 - by Electrothaumaturgist - 08-28-2017, 09:16 PM
RE: 38-1 121A run2 #4 - by Radioroslyn - 08-28-2017, 09:28 PM
RE: 38-1 121A run2 #4 - by Electrothaumaturgist - 08-28-2017, 10:12 PM
RE: 38-1 121A run2 #4 - by morzh - 08-29-2017, 07:53 AM
RE: 38-1 121A run2 #4 - by Radioroslyn - 08-29-2017, 10:21 AM
RE: 38-1 121A run2 #4 - by morzh - 08-29-2017, 01:14 PM
RE: 38-1 121A run2 #4 - by Arran - 08-30-2017, 06:37 PM
RE: 38-1 121A run2 #4 - by Electrothaumaturgist - 03-06-2018, 12:30 AM
There are currently 4088 online users. [Complete List]
» 1 Member(s) | 4087 Guest(s)
