116X plummeting B voltage
Check for negative voltage on the grids of the 6A3's. Should be about -60v. If you don't have it on both grids Check the center tap of the driver transformer (92) If you got it there replace 92. Check for plate voltage on the # 42 tube. If is is low replace (92) Also try removing the #42 and watch the b+ to see if it drops as the set warms up.
116X plummeting B voltage - by Guest - 02-17-2010, 06:15 PM
Re: 116X plummeting B voltage - by 7estatdef - 02-27-2010, 07:28 PM
Re: 116X plummeting B voltage - by Guest - 03-01-2010, 07:34 PM
Re: 116X plummeting B voltage - by 7estatdef - 03-01-2010, 09:11 PM
Re: 116X plummeting B voltage - by Ron Ramirez - 03-02-2010, 09:44 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
